Love that unboxing new car smell...
JVT73
Pennsylvania
Price point & RTR sealed the deal for me and my budget! A special thank you to all those who offered their opinions in my Tropghy Truggy 4.6 pros. vs. cons. post. I pulled the trigger on the Trophy Truggy 4.6 and it is sweat. I'll post more as I dial it in, so far the break in is complete a the engine is singing like a bee! Very good idle and tone.
Hmm, I wonder what you'll be doing this weekend. ;)
Good looking Truggy @JVT73
From what I've been reading I think the Mugen Truggy has a two speed trany in it. I wonder if it will fit in the Trophy, that way I can take advantage of the 4.6, like in the Savage. It would be a real worm burner!
Maybe @Caretaker109 would no, i think he has a Mugen?
Either Tower has a miss print or it's a new Trany. I'm having a hard time finding info on Mugen website.
See below:
Notes from our tech department:
This is the Glow Powered, Radio Controlled, 1/8 scale
MBX7TR Truggy Kit from Mugen.
FEATURES
Chassis:
0.12" (3mm) thick A7075 aluminum, hard anodized,
increased side bends for greater durability
Drive: Four wheel shaft with new front and rear universal style
driveshafts for better feel on bumpy surfaces
Transmission: Two speed, adjustable
Differentials: Oil-filled bevel gear
Shocks: Oil-filled 16mm diameter with 1.4mm springs that reduces
chassis roll, increases traction, improves jumping and adds
stability
Shock Towers: 0.157" (4mm) thick A7075 aluminum
Suspension: 0.196" (5mm) A7075 aluminum lower suspension mounts for
optimized geometry, front and rear steel sway bars
Fuel Tank: 5.07oz (150cc)
Clutch: 13 tooth steel with three heavy duty aluminum shoes
Brake: Dual disc
Bumper: Front foam
Camber Tie Rods: Adjustable, Camber describes the angle at which the
tires sit vertically
Body: Cab forward style, clear with black plastic rear wing
Steering Tie Rods: Adjustable, Caster/Toe-in is the angle at which
the tires point inward as viewed from above
Ackermann: Adjustable, Ackermann refers to the inner front wheel
rotating faster than the outer front wheel during turns
I am sure there has been a mistake.
http://www.mugenseiki.co.jp/mugen/download/manual/manual_e2019.pdf
http://www.rc-speedhouse.com/webshop/mugen-mbx7tr-truggy-nitro-1-8-kit/bRK9K
  • MUGEN MBX7TR - TRUGGY NITRO - ...
PRODUCTOMSCHRIJVING
Artikelcode: E2019
4wd Truggy Nitro
EIGENSCHAPPEN
The MBX7TR and MBX7TR Eco kits have many high-end improvements in suspension, steering and drivetrain to create the ultimate 1/8th nitro and electric off-road truck.
Mugen Seiki concentrated on the making the suspension on the MBX7TR even better with new 16mm front and rear shocks that improve traction and better feeling on high grip conditions. The new shocks are also outfitted with new 1.4mm shock springs. The new 1.4mm shock springs reduce chassis roll, increase traction, improve jumping and are more stability on bumpy tracks. This means you can drive even harder than ever before! The 7TR has a new 3mm A7075 hard anodized chassis with increase side bends to increase strength and to give a more precise felling on all surfaces. The MBX7TR uses the E2129 front upright which has a trailing axle position to improve overall steering. The steering ackerman plate from the 7R buggy is also included in the 7TR to add more adjustability. The servo saver spring was also update to the E2316 to improve the precision of the trucks steering dramatically. The drivetrain of the MBX7TR has been changed and improved with the use of a new universal style driveshaft for both the front and rear of the truck. This greatly improves the feel of the truck on bumpy surfaces. The universal driveshafts will make the overall drivetrain much smoother and will spin with less friction.
MBX7TR Features:
– 3mm A7075 hard anodized chassis.
– Lightweight 46T spur gear.
– Straight cut conical and ring differential gears.
– Fully adjustable steering with new geometry, servo saver and ackerman plate.
– Front/Rear 16mm hard anodized threaded shocks with 3.5mm shock shafts and slim rubber boots.
– 5mm A7075 aluminum front shock tower.
– 4mm A7075 aluminum rear shock tower.
– 5mm A7075 aluminum lower suspension mounts for optimized geometry.
– E0710 heavy duty aluminum clutch shoes.
– Stylish cab forward body.
– E2125-B revised lower front suspension arm.
– New 1.4mm shock springs.
– Improved servo saver spring (E2316)
PRODUCTOMSCHRIJVING
Artikelcode: E2019
4wd Truggy Nitro
EIGENSCHAPPEN
MBX7TR Features:
I agree, thank you for taking the time and effort to dig into this. I was looking for the manual, page 10 diagram 9 shows a typical Truggy center diff. Props to @Caretaker109 for clearing this up.
please keep us posted how everything goes.. I am very interested.
I will, my first mod will be the clutch. I've ordered the optional three pin flywheel, shoes, & springs. I will probably install after the two Shoe wears out, hopefully I can run it this weekend.
