How do u put a starting pin and spring in
Prabhjot
Alberta
Hi I am new to nitro can someone tell me how to put the starting pin in and the spring in the engine is there a trick to put it in
put the spring in the hole first and a bit of grease on the pin and install it just as the instructions say to, be careful installing the backplate and you should be good to go....
Is there a video that I can see or and is that the easiest way
I suppose there must be a video on youtube somewhere..... but if you are careful and use a bit of grease as suggested it will go together just fine
