Oli129
Dear Everyone!
I am a newbie to these forums but not that beginner to the nitro R/C world. I found a topic somewhere a week ago here disscussing such an issue I post here about. However, I have failed finding out what is wrong with my toys.
I own an HPI Savage X 4.6 and a Trophy 4.6 (same engine as on the Savage but the V2) as well. I bought the first in 2012 and the latter last year. A week ago I had to disassemble both. My Savage had a worn clutch issue and a broken pressure spring in the engine, the Trophy simply had too much so I had to replace the rear engine ball bearing. I neither touched the piston nor the sleeve on both, they look just super fine and work as they should.
Note that this is the first time I ever disassembled their engines. So I reassembled, sealed them and they just run quite fine.
BUT, they both engage the clutch at IDLE no matter what I do to them and their wheels keep spinning like crazy all the time.
What I did: Checked the proper clutch position, springs, spacers, washers, bearings, bells. None of them are tight or anything, bells move super freely.
Set all the needles to their default "factory flush" positions. Tried to play with the idle needle, however what I can achive is to either give the engine more throttle or to have it cut off. But the wheels just keep spinning.
I can however block them with the brake or with my hands, but on releasing...start spinning again.
I have spent quite a nice time trying to find out how to solve this, but I am still unsuccesfull.
Could anyone please give me some advice what I should check on the engine or what I am missing?!
These engines look quite simple to me and still...
Any help would be greatly appreciated! Thank you very much! 🙂
Oliver
Oliver
