TheFixxer's "Black Widow"
TheFixxer
100% Addict..There is no hope
Menasha, WI
This is my 2wd TRX Slash. Much like my pede a lot of cash was thrown at it to get is where it is now. I bought it off eBay for $135 and it was a serious basket case. These pictures were taken after it was rebuilt on the HCG chassis, it has since been converted to the STRC LCG. I will post updated pics soon as I clean it up.
Features:
  • Castle Creations 1/10 Mamba Max Pro SCT ESC + 2400kV Motor geared 21/90
  • Venom 6000mAh 80c 2S and 3S battery
  • STRC bearing carriers front and rear
  • Avid bearings throughout including the transmission
  • Hot Racing steering castors
  • STRC hinge and king pins
  • STRC bulkhead, STRC wheel hexs
  • Slash 4x4 drives shafts w/ steel output yokes
  • TRX big bore shocks w/ Losi springs and titanium shafts
  • Kimborough 124 Servo Saver
  • STRC bellcranks and linkages
  • Futaba S3305 steering servo
  • STRC battery hold down
  • RPM A-arms on all 4 corners
  • Stock BFG sct tires pictured but since changed to PL HoleShot2 sct tires on PL Split 6 rims
  • Hot Racing Graphite composite transmission housing
  • Hot Racing HD slipper clutch and graphite pads
  • Hot Racing aluminum sealed differential w/ stock grease
  • Proline chassis saver, Tactic x240 radio system
  • Proline Baja bug body w/ TRX Grave Digger red LED headlights
  • Custom Black Widow decal
  • Venom LVD alarm
  • Duratrax on board temp monitor
  • STRC Aluminum shock caps
