Purple aluminum Hop-up
What are you looking to upgrade you do not want to make your truck solid aluminum it will be an expensive mistake unless you are building a shelf queen been there done that, Integy hd rear hubs are ok and the front c hubs and castor blocks are ok as well if I was you I would stick with plastic a arms plastic shock towers plastic diff case you want these components to flex the more you reinforce one thing it puts the strain somewhere else hope this helps are u running flux or nitro
I was thinking of upgrading the shock towers upper and lower arms. This truck is mainly for show. I have another savage I am keeping the stock plastic on for daily use and bashing.
