Top 10 Upgrades for less than 25$
TwiZtiD
La vernia, Texas
How about some quick easy cheap up grades you can fab or buy for cheap. I love this hobby but I do have a wife who yells at me every time she sees a purchase on my debit card from the LHS so how about a list and or pictures of custom upgrades, setups or low end items to get the most bang for your buck!:devil-smiley-020:
Hot bodies wing mount with custom sheet metal bracket total investment 10$
Center skid plate scrap sheet metal and some rattle cans less than 6$
Also did the fuel tubing mod to help the droop in the
suspention and added 40wt shock oil
I like your mods man. (+Rep) Sig is good too!
I sit here thinking hmmmmm I made a wing mount years ago that is still holding up. Other then that, my back accts have been raped of every last cent over my savages.. (screen name )
how do you do the fuel pip mod on shocks . thanx
Take shocks off remove shock cap, drain oil. Unscrew the plastic piece on the bottom of the shaft. Slide shaft all the way out of the shock body then add desired amount of fuel tubing I used 1/4 inch all the way around. Slide that 1/4 peice on the shock shaft itself slide it all the way up by the piston. And then reassemble. It just takes alot of play out of the suspension. Keeps it low and fast helps with body roll too
if your going to be running the stock linkage setup i would say replacing the spring for the brakes with a piece of fuel line that is just a bit longer then the spring,it makes it easier for the servo to "push" on the brakes.. Made a pretty big difference for me!!!
