mid tank
angellewalsh
ok i saw a fuel pump at tower hobbys it is made by perry, it is a inline fuel pump u think this will work instead of a midtank build
i do not think so because the air bubbles in the fuel lines
NO!!!!! Ive tried it and done writeups on it here. The pump is rpm limited and will not deliver fuel at high rpm resulting in way lean mixtures.
Ive also tried two different fuel regulators which also don't work on car applications due to the large carburetors that these engines use.
Mid tank or raise the stock tank works.
mid tank builds are not required. People do them for a few reasons. 1: Something to do 2: better balance for racing 3: Bigger tank longer run times also eliminates mid tank lean issue some people get(i've never had)
