Cold plug?
sharkattack99
Moses Lake Wa
can i use a cold plug in my picco for break in? i didn't realize that the piccos didn't come with one and all i have on hand is a dynamite platinum cold plug. will be running 20% for break in and then i will be running 30% from then on.
you can use any plug you wish. There is no "rules" to it.
A hot plug is good for noobs during run in but can also cause damage in the same right as some don't know to not let it spool up the RPM with the hot plug and they let it detonate...
thats good i thought maybe it would make the break in process harder or something.
lol it will. But you can still do it. the hot rage plug is just that it burns "hot". Cold is cooler and flames out easier. Its like advancing/retarding timing on a 1:1 but all will work
interesting topic bank can you explain the spool up detonate thing a little clearer?
my savage came with a 5 what should i run long term a 3 or 4 ?
