Mid-Tank Conversion, am i set ??
xll-SavageX-llx
★ CaNaDa Eh ★
Hamilton Ontario
Hey guys after i got my FLM EXT TVP's iv been thinking of doing a 250cc Mid-Tank Conversion..
So here is what's on my list so far..
• FLM 45500 - Servo Plate
• FLM 46000 - Servo Mounts
• CEN FF007 - Radio Box
• OFNA 19504 - 250cc Fuel Tank
• OFNA 10724 - Linkage kit
• OFNA 10704 - Linkage Sliders
• OFNA 30661 - Heavy Duty Servo Horn Kit
If i am missing any thing just reply and give a link 🙂
...and to mount the fuel tank i was thinking of getting some aluminum rod from Canadian Tire and tapping it out to the right size of the screw i will be using..
As Tarnish said the blue linkage doesn't come with the ball joint, so i went with #10723 (Orange Linkage) and #10702 (Black Sliders), thanks again Tarnish for the info
looking good Brandon. you can dye all that stuff black with rit clothing dye so it don't matter what colors you get
I was thinking about that, i might just do that 🙂
Like Tarn said all the other linkages have the ball join except the blue...
I beleive you asked about using the CEN Batt Box on the side there was a member that done that. I think his name started with S. I will try and find it.
If I'm not mistaken the OFNA 250cc tank won't fit on the FLM servo plate, the tank is too long, you need the Platinum RC carbon servo plate ideally or make up your own plate that's longer to accommodate the OFNA tank.
I'm not 100% on that though so may be wrong.
This is correct and he asked in another thread as well.
Yeah i found that out after the fact, but i would rather fab my own just because the CF would look weird with the aluminum...
I would get the CF servo plate if i had CF TVP's, CF skid plate. CF roll bar LOL
Yea I have never seen that here. Looks like brandon needs to make a thread about it .... :resp:
I have seen it mounted where most people put the RPM box at(front left). It looked cool, so I am going to try the two mods to see which one i like better. Only thing is that the CEn battery box might stick out too much. Who knows unless someone tries it. So i will.
Cool cool..
