If you do get the RSC, you do NOT need LXEKJ9. It will no longer be compatible.
What is RSC, something Suspension Conversion.
I am pretty sure the RSC comes with the HPI adjustable arms previously mentioned as tower hobbies #LXEKJ9 or HPI #85066.
Also, I saw you mentioned hellfire upper arms... do people use hell fire parts for tie rod end links? If so, what part numbers?
This is what I always wanted to know...
All the rear hub carriers that eliminate the tie rods are never wide enough and require some type of spacer or bushing... even the HPI brand name one require a spacer. Why not just make them the full width, then instead of bending a hinge pin it would actually need to shear off.
With the spacers it would allow you to change the wheel base but you'd never notice... maybe on a pan car or something. Maybe you could move it forward or backward to help the upper arm clear some of the larger single shock setups? (won't help the front clear though)
