Bearings anyone..?
Little more info here paddawon. You having trouble taking of a bearing? If so which one? Depending on the bearing I use either a booger picker or a small screw driver from the opposite side.
Usually a small screw driver. Most of them on the savage come out pretty easy with a little push. When they are pressed in usually a bearing puller, sometimes some heat. If they are larger bearing and stubborn a socket or something. Usually go for the outer race.
Nah i don't have to get out a bearing i was just seeing how people do it. that way i know how instead pf tearing up the bearing.
