My project : a savage brushless in carbon
Guix67
Hi all,
I present my project. With a friend, we are making a Savage brushless in carbon. For the moment I’ve only some pieces and 3D of the chassis and the motor mount. The chassis will be longer as a savage X.
The hop ups I’ve :
-Genesis differential
-4 GST shocks
-FLM aluminium towers
-Futaba 3PM 2.4GHz
-red screws
-Baja bug body for extended chassis
-Hitec HS-7955TG titanium gear digital servo
-Servo saver savage X
-Badland and Crime Fighter LPR tires on praline velocity ½ Offset 17mm
What I’m going to buy :
-Bling Racing CVD driveshafts with 17mm hex.
-MBX6T center diff with diff mount
-Savage Flux battery box
-Savage X bulkheads
-A motor
For the moment I've the esc : a MGM 16025-3 160A 🙂
Some pics :
The genesis shocks with the flm towers.
The MGM esc
The baja bug body
The screws with the cen diffs
The cen diff
Then the 3D
We've done a rear motor mount because my friend got a NEU 1527 1D and it's fat 😛
The first 3D we've done:
The last 3D (they're is not finished) :
So now i search a Castle/neu 2200kv motor.
The center driveshafts will be done by a manufacturer.
And sorry for my bad English but I’m French ^^
Looks to be an awesome build man, i think id be inclined to go with either the lighter and stiffer flux bulks or even alloy bulks as opposed to the X bulks though.
Thanks all for your comments 😉
I know but a friend give me his X bulks ^^.
Thanks
I want a light savage but a resistant too ! I will use it only for bashing so it has to be resistant.
Looks like it is going to be a sweet build, Guix.. Can't wait to see more pics..
😛eace:
Like Bank stated if you are using Quasi-Iso sheets you can remove quite a bit and keep the strength, if not using Quasi you can remove some but don't go to far.
How thick are you going with it?
Looks like you have a great start. I assume your using the wide skid to mount battery's? Keep up the great work and keep us updates.
Hi,
What do you mean by Quasi ISO Fiber ? A good quality of carbon ?
All the carbon parts will be in 3 or 4mm (it depends of the price).
Thanks amm for your positiv comments 🙂
Hi,
I want a light savage but not th emightest savage in the world ^^ I want a strong and light savage that's why i don't remove some carbon.
Some pics of the complete 3D 🙂 Now i have to find a place for the servo :
Very sweet. Great detail as well.
However, if you use Quasi-Iso Carbon you can remove quite a bit of material with out sacrificing the needed strength. Take a look at how much my TVP's are cut out and they are still probably close if not the strongest TVP's on the market. Granted I use a very high quality carbon Fiber.
Hi,
The TVP has been shiped monday by platinium RC. I hope i will receive them soon and then i'll test all.
But i already have this esc on my MBX5T BL and it works perfectly 😉
PRC cut my TVPs. It isn't prc's TVPs.
ok, now I'm really dying to see these.
The PRC stuff looks good & all in pics.
But just wait till you actually get them in your hands..... you will drool.
Man I'm glad to see this thread & build moving forward, you really put some good work and talent into the design.
Hello,
I received the TVP's last week but I was on holidays ...
Some pics :
It's beautiful ! And it's a very good quality 🙂
It Weights 581g !
