SwampDawg
- Location
- Interior BC
awesome!! i just got a truck similar to this!
ok shocks ball diff (ill run it till it blows up) tranny slipper all done on mine taking a break ...
For shocks I'm using Erics Shauvers set up first time out on the ESE, Ill adjust it from there. Anything has to be better then my rtr blitz..
Front:
I did front shocks with the #3 spacer
A Piston.
Team losi 25 wt oil that is = to 294 on the cs scale or 30o wt .. HPI-30
84.5 MM
Rear:
No spacer
B Piston
Losi 27.5 = to 345 or near 35o wt HPI- 35
102.5 MM
Justin, where'd you find that info at?
If I told you Id have to kill you ... Mines almost done just gotta put on the rear end. You done yet?
Mines done .. 7 hrs with 2 breaks to check threads here. I did a few extras. PMing you with the extras. I don't want to post it in your thread ... Ill make one another day...
Must be nice. I've probably got about 1 1/2 - 2 hrs. build time into mine. 30-45 min. a day for the past couple days when I was able to sneak in the time. Never got a PM from you abut the extras. Let me know what's up.
I was going to show you the dye job and not post it but I ended up making that thread.. I cant stop once I start a build unless I need parts.. I'm like a addict. wish I could walk away!
Inside hole 3 MM of Spacers, middle hole on the hub 49.5 MM buckle inside to inside. shocks in top center and low inside on arm 2+ kick and 4 toe block. the body puts allot of CG high. this helps fight it..
I'm tweaking off this sheet. It felt a lil better then my rtr from the start but I still don't know ATM. I only ran one pack w/o the timing system. I don't know if I improved anything.
http://www.hpiracing.com/filehost/Blitz_Setup_Beta_3.17.2009_OC-RC_TG_web.pdf
Cool deal, thanks for tips Justin. Got 1 more step done today. Gonna take and post pics tomorrow.
Cool, keep plugging away.
