bebekhijau
Hi all, my savage xs flux has issue with rear tires. When up in the air, all four tires is spinning, but when i put rear tire to the ground while front tires in the air, the car wont go forward. It seems there is gear slipping sound so no enough power to launch it forward.
While if i put front tires to the ground while rears in the air, it launch at full power
I already disassemble rear diff, clean it and thoroughly inspected it but cant find any wear on it. Inspect all wheels and center drive shaft, all good. Also adjust slipper clutch to max friction.
Any idea what cause this problem ? thanks
