MikeK1981
ChondroManiac
- Humboldt, CA
OK guys, I'm having a strange issue that I can't seem figure out. I lost my carb pinch bolt a few weeks ago and I damaged the o-rings taking the carb out. So I put new o-rings on the neck and put everything back together. After running it a few times I noticed there was fuel getting all over the case. After cleaning it up and checking periodically I'm pretty sure it's coming down form the carb neck and not the crank shaft area. I took it out again and applied copper sealer very carefully around the area where the carb butts up against the case and it seems to have helped, but it is still leaking a bit even with the sealant and the o-rings in. You guys have any tips or tricks when it comes to getting a good seal there?
