want to stay above 200, and under 300. 220-250 is perfect for me.....sometimes 260 but it just depends on the day and plug, ect. that I am running.
Hope this helps.
Oh Fahrenheit also....
Between 260F and 280F she screams. Over that and you run into trouble.
Yes, most nitro engine temp ranges are between 230-260*F. Some will run cooler and some hotter. Altitude, humidity, ambient temp and all make a difference along with running or not running a body.
My engine's typically run around the 260 range at best performance but my F4.1 ran best at 290-300 it would scream believe it or not. I had 8 gallons on it and the only reason it dies is because I cracked the block and temps went to 500 or so and roasted it immediately.
I in any way shape or forum recommend not running them at 300* consistently unless you know what your doing. I was simply stating that i had a mill that ran that and loved it.
The best way to tune is by sound, performance and Smoke Trail, not by Temps.
