Stop Pinion from moving
Crash
Chicago
hi guys
I a Flux and seems that after a couple packs the pinon seems to move on me.
I tried red lock tight...
When I try to tighten those lillte grub screws they strip out on me, had to drill 2 out already...
Any one consider drilling out the draft shaft to fit a pin like the drive shafts?
thanks
Dan
I have only run 6 packs on mine but I got away with Blue and it cranked down. I didn't have stripping issues reefing on it using HPI's pinions... Also let the blue set for 24 hours b4 I used it.
i have this problem... its hit and miss really.
Red Loctite worked really well... I applied it to the shaft and the screw... a pain to get off unless you have a heat gun....
using blue at the moment in teh same way, and its doing fine... but i did have it move on me recently.....
I don't think its really necessary to drill the drive shaft. I would just try red again and let it set properly...??
yup blue here with a longer cure time and cranked down with a good driver.
thanks men
I remounted it and adjusted the mesh
test it tooday
:chainkiller:
