Hi. Make sure that the servo cable is connected to channel #1 output of the receiver. Maybe the trim button that seems to work is for another channel different to #1.Hey guys,
After my transmission problem i reassemble everything. This time car does not steer. First i thought that the servo is dead, but i can steer it with trim button. So would you help to identify my problem? Might that be an esc or receiver problem?
Hi. Since steering was working before you disassembled the car It is not probable that servo, receiver or transmitter are broken. I would focus on checking electrical connections, transmitter settings and mechanical assembly.It was on the #1 channel, it looks fuzzy on the video. You can see throttle works as it it should be at the end of the video. Any other suggestions?
