Slipper Clutch XS
VMAN
Ok so I finally got my parts from HPI here to Afghanistan. I instll the speed controller and run a pack though it without any problems, and the truck performed great! Well the 2nd pack I was driving along and it started slipping. No grinding or anything just slipping. My guess is the slipper clutch needs adjusting. Any other ideas? Its looks to be kind of a pain to get to. Has anyone done this on an XS Flux? Thanks!
it tells you in the book how to adjust the slipper. but basically you need to tighten that up by using a 10m spanner on the nut go in from the side and once your on the nut then roll the truck back until the wheels lock up. and get used to doing that or put lock tight on the nut.
I have a big issue with the slipper clutch as well. No matter how much I tighten the slipper, it starts slipping big time a couple of runs after. It slips so much that it becomes loose and the truck won't move even though the motor is going crazy fast. Is there a solution to this??
I also heard double nutting it would help too. I'm getting ready to try that.
