baris41
Hi Guys,
I have several questions, if you answer the following questions, i'll be really appreciated.
1. My rc doesnt move anymore. I guess the problem laying down on Idler Gear. Why do you think this might happen? (see on the youtube video).
2. You can see the current situation of the motor in the pictures. I cleaned all the old grease. Which kind of grease should i use on the reassemble? Is joint grease up to the task? (see it on the pictures)
3. What do you think about the slipper clutch? Does it look good or do i need to maintain anything? (see it on the pictures)
4. Also the plastic cover of the engine and the cylinder plastic part behind the slipper clutch were worn out, is it normal and should i replace them? (see it on the pictures)
Thank you.
Thank you.
