Questions about Trencher X Tires?
Champmoney
I just got these tires. I have the Savage HP Flux. Before I use these tires should I be changing the gearing? Incase of over heating. Also will I need a better steering servo? Any info on these.
If you have a Rtr flux a steering servo upgrade is always a good idea. As for the tires how much taller are they then the stock tires? That will determine your gearing issue
Yes they are a bit taller. I'm gonna wait till I get a new steering servo before I use them. I'm gonna try the same gearing and see if anything heats up.
Do you know what the stock pin is on the HP flux?
