Gazzman
- Haywards Heath, Untied Kingdom
So this is one of the engines I got with the 2 Savages I purchased over Christmas. It's an HPI NitroStar S25 and had been sitting unused for around 2 years so I decided to strip it out and have a look inside. The engine was pretty gummed up with old fuel but everything looked good. Cleaned every part, lubbed it all up and re-assembled it. Did put a new pressure pin & spring in it while was apart. The compression was good but is now even better. The carb was also stripped and cleaned and the tune on it seems not to bad for the 1st start-up, will need fine tuning when I get it out for a run. but there doesn't seem to be any leaks from the backplate or front bearing which is good news.
And before anyone asks why the rear right wheel isn't spinning well that's because I am still missing a drive shaft for it.
