Do the wheels turn? Is the esc pluged into port 2 on the receiver?
Oh I've gone through the manual a million times and there is no info that would explain the issue I am having.Do you have the manual with this vehicle, if so most of that should be detailed there....
if not download a copy here >>>>> https://www.hpiracing.com/instructions/115116
Out of the box esc. Using the NiMH battery it came with. I have some experience as I just got back into rcs having them as a kid.Ok so on to the ESC , what brand and number does it have ? are you the original owner and do you have some basic R/C experience to draw from, also is it LiPo powered or are you using NiMH batteries with the model??
Can you explain? Don't know what this is.Also have you tried rebinding the TX and RX, sometimes they get lost and need rebinding.....
Page 34 of the jumpshot sc manual explains the binding process.Can you explain? Don't know what this is.
Tried it no luck. Should the esc be blinking red the whole time?It is in the radio portion of your jumpshot manual, follow the binding directions for the transmitter and receiver
