Is it possible to use 2 different LiPo brands at once?
Jelle318
Is it possible to use two different brand lipos, but same C rating and Mah rating and voltage, in series wiring? Like for example; use a Gens Ace 5000mah 50c 3s and a Team Corally 5000mah 50c 3s in a Series Wiring?
Thank you,
J.
The idea is that the batteries should hopefully discharge similarly. If they discharge unevenly there is the potential for damage. Even between the same battery that may differ a little. The need is to atleast have batteries with the same C rating, capacity, type and cell count. Atleast then the possibility for failure diminishes. Just keep your eye on the cell voltages and balance charge when you can.
