HPI Savage Octane Manual and Parts Listing
Status
Not open for further replies.
WoodiE
Kind of good admin
HPISF Staff
Kentucky
HPI Savage XL Octane Manual (model #: 109073): http://hpiracing.com/en/instructions/109073 (mirror)
HPI Savage Octane Parts Listing
Chassis Components
#105891 - Upper Arm Brace 4x54x3mm
#105892 - Bulkhead Lower Plate 2.5mm
#105893 - Lower Arm Brace 4x54x3mm
#108934 - Roll Bar Set
#108938 - Radio Box Set
#108940 - TVP Chassis (Right/Gray/3mm)
#108942 - TVP Chassis (Left/Gray/3mm)
#108944 - Fuel Tank Set
#108946 - Steering Servo Mount Set
#108956 - Engine Plate (Gray/4mm)
#109786 - Roll Bar Parts/Tank Mount Set
#111295 - Joint 19x54x20mm
#111297 - Steering/Throttle Rod Set
#85059 - Bumper Set/Long Body Mount Set
#85234 - Skid Plate/Body Mount/Shock
#85235 - Gear Box/Bulkhead Set
#86803 - Joint Post 4x6x74mm (2pcs)
Drivetrain
#105551 - Sintered Bulletproof Diff
#107456 - Slipper Pad 16x33x1.0mm (Tsc)
#109040 - Drive Gear 24t (3 Speed)
#109044 - Drive Gear 30t (3 Speed)
#109046 - Idler Gear 38t (3 Speed)
#109052 - Idler Gear 32t (3 Speed)
#109268 - Brake Hub 6x8x19mm
#109448 - Center Gear Box Set
#109907 - Drive Shaft 8x70.5mm
#111094 - Third Gear Clutch Holder
#111097 - Second Gear Clutch Holder
#111167 - Idler Gear 31tx1m (Steel)
#111169 - Drive Gear 30tx1m (Steel)
#111800 - Heavy Duty Spur Gear 47tx5mm
#111802 - Drive Shaft 6x73mm
#113002 - Spacer 8x12x14mm
#72130 - Stainless Steel Slipper Plate
#72367 - Brake Spring 4x5x20mm (2pcs)
#77054 - Spur Gear 44 Tooth (Savage 3
#77058 - Pinion Gear 18 Tooth (Savage 3
#86054 - Dogbone 8x142mm (Black)
#86081 - Gear Shaft 6x12x78mm (Black)
#86082 - Cup Joint 6x13x20mm
#86083 - Cup Joint 8x19mm (Black/2pcs)
#86094 - Screw Shaft M4x2.5x12mm
#86095 - Screw Shaft M5x3x18mm
#86099 - Diff Case Washer 0.7mm (6pcs)
#86130 - Slipper Clutch Hub
#86246 - Super Heavy Duty Drive Shaft
#86248 - Super Heavy Duty Diff Shaft
#86249 - Super Heavy Duty Wide Axle
#86362 - Clutch Gear Hub (Savage 3
#86804 - Hex Wheel Hub 17mm
#86827 - Alloy Diff Case
#87042 - Spring 4.9x8x7mm/Washer 4
#87193 - 4 Bevel Gear Differential
Suspension & Steering
#100948 - Shock Body Set (113-157mm)
#100949 - Shock Parts Set
#100950 - Shock Shaft 3.5x90mm (4pcs)
#100961 - Shock Cap Set
#102365 - Big Bore Sport Shock Set
#102522 - Heavy Duty Servo Saver Spring
#105894 - Steering Post 12x47mm
#15415 - O-Ring (50x2.6mm/Black/4pcs)
#6561 - Spring 18x20x1.7x5 (Black/2pcs)
#6811 - O-Ring 6x9.5x2mm (Black/8pcs)
#75075 - Silicone O-Ring S4 (3.5x2mm/12pcs)
#75080 - O-Ring 7x11x2.0mm (Black/8pcs)
#85048 - Upright Set
#85058 - Steering Crank/Servo Saver Set
#85231 - Shock Spacer Parts Set
#85238 - Suspension Arm Set
#86059 - Ball 6.8x7.3x3mm (Black/4pcs)
#86071 - Flange Shaft 4x62mm
#86073 - Shaft 4x78mm (Silver/2pcs)
#86074 - Shaft 4x46mm (Silver/2pcs)
#86090 - Steering Crank Post 6x49mm
#86551 - Shock Spring 18x80x1.8mm 14
#86555 - Shock Spring 18x80x1.8mm 10
#87058 - Rubber Tube 3x8x10mm
#87500 - Bladder 16x5mm (Flat Type)
#87524 - Rubber Bump Stop (4pcs)
#93535 - Turnbuckle M4x70mm (4pcs)
Engine & Engine Parts
#108948 - Throttle Servo Saver Set
#108960 - Clutch Bell 14tx33x20mm
#109054 - Air Filter Set
#109061 - Inner/Outer Foam Element Set
#109258 - Carburetor (Wt-668) (Octane 15cc)
#109762 - Gasket 11x28x42x0.5mm
#109784 - Exhaust Spring 0.9x5x13mm
#109866 - Fly Wheel 9.6x43x16mm (Quadra)
#109904 - Engine Mount Set 25x30x78mm
#111335 - Woodruff Key 2.5mm
#111337 - Thermal Insulator
#111338 - Ignition System
#111339 - Spark Plug 14mm (Cm-6)
#111340 - Heatsink Head (Octane 15cc)
#111341 - Cylinder Liner/Piston Set
#111342 - Connecting Rod (Octane 15cc)
#111343 - Crankshaft (Octane 15cc)
#111345 - Recoil Starter
#111346 - Timing Sensor
#111350 - Aluminum Quadra Clutch
#111351 - Air Filter Joint Set
#111390 - Octane 15cc Engine
#111392 - Head Gasket 0.2mm (28x34mm)
#111790 - Cooling Fan Unit Set
#112387 - Crankcase (Octane 15cc)
#112388 - O-Ring (35x39mm)
#112389 - Crankcase Plug (10x12x7.6mm)
#112488 - Manifold 21xm4x90mm
#112494 - Muffler 19x56x180x11mm
#112654 - Muffler Mount / Hanger Wire
#112655 - Intake Air Reducer Set
#113241 - Idle Adjust Washer Set
#15465 - Air Filter Gasket (2pcs)
#86710 - Silicone Exhaust Coupling
#87469 - Fuel Tank Cap
Electronics
#104058 - HPI TF-20e 2.4ghz Transmitter
#104060 - HPI RF-30 Receiver 2.4GHz /2ch/6V 5cell Battery)
#104105 - HPI SF-10w Servo(Waterproof/4.5kg-cm6.0V)
#105366 - HPI SF-50wp Servo(Waterproof/12.0kg-cm6.0V)
#110208 - Servo Extension Wire 190mm
#110721 - Receiver/Ignition Switch
#Z150 - Antenna Pipe Set
Batteries & Chargers
#111834 - Ac Multi-Plug Charger With
Hardware
#109473 - Step Screw M3x4x22mm (2pcs)
#110211 - Binder Head Screw M3x25mm
#111298 - Tp. Flanged Screw M3x15mm
#111336 - Button Head Screw 4-40x8mm
#112933 - Cap Head Screw M5x50mm (2pcs)
#6122 - Body Pin
#6123 - Body Pin
#6163 - Servo Tape 20x100mm (10pcs)
#72111 - Shim Set 3x5mm (M3x5x0.1-0.2-0
#86972 - Washer 6x15x0.2mm (6pcs)
#87511 - Servo Grommet (8pcs)
#94505 - Cap Head Screw M4x12mm (10pcs)
#94506 - Cap Head Screw M4x15mm (10pcs)
#94520 - Cap Head Screw M4x50mm (6pcs)
#B021 - Ball Bearing 5x10x4mm (2pcs)
#B023 - Ball Bearing 6x13x5mm (2pcs)
#B026 - Ball Bearing 6x12x4mm (2pcs)
#B032 - Ball Bearing 10x16x5mm (2pcs)
#B085 - Ball Bearing 8x16x5mm (2pcs)
#Z224 - Washer 3x8mm (10pcs)
#Z240 - C Clip 8mm (4pcs)
#Z243 - E Clip E3mm (10pcs)
#Z245 - E Clip E5mm (10pcs)
#Z260 - Pin 2.5x12mm (12pcs)
#Z282 - Step Screw M3x14mm (4pcs)
#Z286 - Step Screw M3x20mm (6pcs)
#Z288 - Step Screw M4x20mm (4pcs)
#Z303 - Cap Head Screw M3x42mm (6pcs)
#Z421 - Cap Head Screw M2.6x8mm (12pcs)
#Z488 - Tp. Flanged Screw M2.6x12mm
#Z515 - Binder Head Screw M3x5mm (6pcs)
#Z516 - Binder Head Screw M3x10mm
#Z518 - Binder Head Screw M3x12mm
#Z519 - Binder Head Screw M3x15mm
#Z520 - Binder Head Screw M3x18mm
#Z525 - Flat Head Screw M3x6mm (10pcs)
#Z527 - Flat Head Screw M3x10mm (6pcs)
#Z529 - Flat Head Screw M3x15mm (6pcs)
#Z530 - Flat Head Screw M3x18mm (6pcs)
#Z541 - Cap Head Screw M3x6mm (6pcs)
#Z542 - Cap Head Screw M3x8mm (12pcs)
#Z543 - Cap Head Screw M3x10mm (6pcs)
#Z545 - Cap Head Screw M3x15mm (6pcs)
#Z547 - Cap Head Screw M3x20mm (6pcs)
#Z567 - Tp. Binder Head Screw M3x10mm
#Z568 - Tp. Binder Head Screw M3x12mm
#Z569 - Tp. Binder Head Screw M3x15mm
#Z570 - Tp. Binder Head Screw M3x18mm
#Z581 - Tp. Flat Head Screw M3x18mm
#Z613 - Binder Head Screw M4x10mm
#Z623 - Flat Head Screw M4x12mm (6pcs)
#Z632 - Tp. Binder Head Screw M4x10mm
#Z634 - Tp. Binder Head Screw M4x15mm
#Z644 - Tp. Flat Head Screw M4x15mm
#Z649 - Tp. Flat Head Screw M4x30mm
#Z661 - Lock Nut M2.6 (4pcs)
#Z663 - Lock Nut M3 (6pcs)
#Z680 - Flanged Lock Nut M5x8mm
#Z684 - Flanged Lock Nut M4 (4pcs)
#Z685 - Washer 2.7x6.7x0.5mm (10pcs)
#Z694 - Washer M5x10x0.5mm (10pcs)
#Z700 - Set Screw M3x3mm (6pcs)
#Z721 - Set Screw M4x4mm (4pcs)
#Z852 - Washer 5x7x0.2mm (10pcs)
#Z877 - Washer 8x10x0.2mm (10pcs)
#Z892 - Washer 10x12x0.2mm (10pcs)
Bodyshells & Body Accessories
#112828 - Gtxl-1 Painted Body (Black)
Wheels & Tires
#3188 - Mag-8 Wheel Matte Chrome
#4465 - Terra Pin Tires S-Compound
Fuel & Fuel Accessories
#87467 - Fuel Line (Black/50cm)
#87468 - Fuel Line (Yellow/50cm)
Tools
#110562 - Spark Plug Wrench (14mm)
Status
