All servos twitch
Cj leclair
Hi I'm cj and all my servos on my savage twitch and i have replaced the batteries and this only happens when i turn the remote on and even then there is little to no response from the truck when i do anything on the remote and the steering and throttle servos are the ones twitching any ideas would be great.
Thank you
would be helpful to know what radio system you have, also if using dry cell batteries, and if all your connections are tight and they way they should be..... Dry cell batteries do not have enough voltage for high draw servos so use a hump type 5 cell rechargeable pack also would help to know if it is used or new, the stock electronics provided do not work very well at all and only really work enough to get your truck running.....
So it was used by my uncle and he made sure it was running befor i got it but now theres this problem and i do have the rechargeable so ill charge that amd set that up and the radio system is the RF6 2 channel receiver with the TF3 2 channel radio
Does it use 4 rechargeable AA's or a 5 cell receiver pack? Also, what's in the transmitter, rechargeable AA's or typical alkaline's?
I have both the 4 AA's and the 5cell pack, the transmitter uses normal alkaline
Mine did that and it turned out to be bad servo's I changed them it's perfect now they do get tired from use and need to be replaced especially on a heavy truck
ok cool thank you I'm going to take both my trucks to the hobby shop and get servos and other things thank you for your help
