SMaxxin
- Location
- South Louisiana
- Thread starter
- #31
I installed the JP-2 pipe and did some tuning today and this thing is bad ass, it has plenty of low end power and the pipe really helped the mid range rpm's. After getting it warmed up I made a few adjustments and the first time I got on it hard it flipped over while shifting into second and the pipe came undone. This pipe uses springs to connect to the header and the stock header uses the rubber boot, the pipe goes in the boot and I did zip tie it but it doesn't go in for enough. I can run it around the yard but if I get rough with it the pipe will pull out....pulling out is always disappointing!
