If it's really low/early, it's hard to hear. If your slipper is slipping, it's also hard to hear. If your clutch is slipping... hard to hear.Anyone know what the trick is to recognizing the gear shift from first to second ? I can never really tell . Turn the adjustment for second out half a turn and still can’t tell
Yes. Just 2 speed. I had a 3-speed savage once, but it was a pain to get shifting right and I sold it along with the truck. This is just a stock savageX transmission in this one.You can definitely hear the shift on the truck in the first video. Does that truck have a 2 speed transmission ?
The more you turn tight/clockwise the later the shift point becomes.Anyone know what the trick is to recognizing the gear shift from first to second ? I can never really tell . Turn the adjustment for second out half a turn and still can’t tell
I would take some sand paper just to scuff the surface of the new pad, clean the surface of the metal slipper plates and gently sand those as well.Well I finally got it so I can here the shift but goes into second almost right away . Of course I was ripping it on a hill and burned out another slipper pad ! Almost new pad and the nut was tightened so the spring was completely compressed . Dam
If his is shifting from 1st to 2nd too quick, doesn't he have to take the top off to change the 1st gear shift? I thought the 2nd -> 3rd was the one that was adjustable externally. Been a while since I had a 3-speed.That is what mine was doing. Luckily the second gear clutch is adjustable without opening trans. I’d tighten down a little more so you can get more out of 1st gear. Helped mine a lot.
So my local hobby shop tells me hpi is as good as closed . To add insult to injury they apparently discontinued the xl 5.9. Once they are out of parts they have in stock that’s it . Anyone know of a source of parts for hpi that will be around for years to come ?
Had a look at some of them, they probably would fit. I might get ken just to see, they are hardened steel as wellSomeone earlier had recommended Robinson racing spur gears . I did go to the web site
