will the 5.9 fit into my .25 chassis?
i just tried to fit my 5.9 motor into my spare .25. i am having trouble with the header. the 5.9 is more of a sweeping bend where the .25 makes a sharp turn out of the mil. as of now the header is making contact with the shocks causing the mounting hole to not line up. i will try to use the .25 header and run it today if i get a chance and let you know of any power issues.
The 5.9 header is meant for the XL there is alot more room behind the motor so its more like a buggie/truggie header. I'm pretty sure the .25 header will work....
threw the .25 header on then i saw i had to change out the clutch bell from the 5.9 with the 14t from the .25 as of now it looks like it will work. just waiting of the battery pack to charge
