Will i be fine running traxxas top fuel in my savage X 4.6?
It will run, but Traxxas fuel is formulated specifically for Traxxas engines and won't perform as well as a fuel like SideWinder or Byrons will....
You have to keep in mind Traxxas fuel is formulated for small block and mid block engines like the 2.5 and 3.3 that they produce, it is not really a big block fuel, it most likely will not damage your engine but it is not going to perform at its peak.....
From what I've experienced, traxxas top fuel has a lot of oil in it, since it's intended to be for people just starting in the hobby. I've been around people running it before and it does spit a lot more oil out than my byrons 2500 race fuel. Odonnel was similar to it.
Regardless, it won't hurt anything to run it.
Ok yes I just attempted the Top fuel in the savage and yes instantly it starting performing super poorly smoked like crazy coming out of my exhaust I was scared to even make a run around to attempt to even try to tune it to the top fuel instantly turned ny truck off emptied out the gas can ill wait till i get the proper fuel to run the truck again and that wads my experiance today with traxxas top fuel guys
Smoke is a good thing. If you have the experience, you just needed to slowly lean the truck out a bit. Smoke means lubrication
