my tires don't spin if i got the truck off the ground...and ive never had a problem with the truck stalling cus of low idle.
Just replace the weak .9 springs with some .9 or 1. springs and that will fix the wheel spin. But honestly, as long as the truck doesn't try to drive off on you when its on a flat smooth surface than it should be fine.
As for the glitch. Check your antenna wires for cracks or holes. Check all the bearings for one that's seized or broken. Make sure all your batteries are charged or new.
