Wheels and Tires (Want Opinions)
Discussion in 'Wheels & Tires' started by SavageLyfe, Oct 22, 2016.
  1. SavageLyfe
    SavageLyfe Active Member
    82
    11
    Oct 15, 2016
  2. Jam Racing 1
    Jam Racing 1 NPTB Monitor, Master of the known universe.... HPISF Staff
    3,921
    512
    Jun 20, 2008
    Those are 1/8 buggy wheels they are considerably smaller than Savage X wheels are.look for a 3.2 truck wheel with a 17mm hex of which there are several that will work well, Ofna, Losi Duratrax , in fact some sell wheels and tires all mounted up saving some from gluing their fingers to their new tires.....
    • Like Like x 1
  3. Jam Racing 1
    3,921
    512
    Jun 20, 2008
    https://www.amainhobbies.com/search?s=Monster+truck+wheels
    found this stuff at A Main. some of them are 4" which equates to a 3.8 wheel so a 3.8 tire will be needed....
    RPM is 3.2 which is more common, they also widen your rig by 1" making it a bit more stable and as long as your tires are 3.2 dia inside they will fit those type wheels...
    A Main is very helpful if you call them they can help with getting the correct sizes so it all fits correctly
  4. SavageLyfe
    82
    11
    Oct 15, 2016
    Alright I'll check that out just looking for some light weight rims and I like the pro lines and I need tires I like the dirt bonz ones gonna keep looking
  5. olds97_lss
    olds97_lss Well-Known Member
    1,024
    163
    Oct 2, 2015
    Dekalb, IL 60115
    What kind of surfaces do you run on?
    I run traxxas 3.8 rims/tires on 2 of my trucks and SRC belted tires/wheels on my OS21TM revo. I may move those tires to my savage since it's faster and may benefit more to help against ballooning.
    I'm currently running traxxas geode (1/2 offset 17mm) wheels with traxxas 3.8 chevrons on my savage and my BB revo. I run on grass and pavement mostly. Those tires don't have a lot of sidewall, so things stay pretty stable at higher speeds. They also don't have a ton of side grip, so it slides in the grass a bit vs doing a traction roll. Also, they have a lot of tread/contact patch, so they don't wear out fast when I run at a skate park or do high speed flybye's on pavement.
  6. SavageLyfe
    82
    11
    Oct 15, 2016
    LOL see that's the problem I run on asphalt sand dirt and concrete!
  7. SavageLyfe
    82
    11
    Oct 15, 2016
  8. olds97_lss
    1,024
    163
    Oct 2, 2015
    Dekalb, IL 60115
Share This Page
