wheels and nuts
So you bought wheels without knowing what they fit? Not smart, lucky for you they are 17mm hex. So yes, they will work....
the only ones i can get are the warlock 17mm hex (first link) they cost around $60... hard times...
Like anything if you do not do the research first and just buy a bunch of parts you will most always have things that just do not work together....
Those are the stock nuts those are the ones I have.
And they work just fine if you don't allow them to loosen and strip the hex. Been running my stock set for 8 or 9 years and they are still in good condition.
Well, you said yours were stripped... wasn't real sure why you were going for some aftermarket thing when $ is limited.
To make mine last longer, I cut the end of my hex wrench off flat so it bites more of the nut:
A normal nut driver on the left and one I cut the end off of on the right. This really helps with those HPI wheel nuts.
