What Shock Towers to use
Discussion in 'Suspension' started by Savage 6768, Jun 27, 2018.
  1. Savage 6768
    Savage 6768 Active Member
    Mar 28, 2018
    51
    9
    New Zealand
    Hi all
    What is the best shock tower to use Standard or Alloy when using just the 4 big bore shocks or is there mod that can be done to brace the shock tower, reason being have noticed the rear shock tower seems to be bending inwards on my savage CD build. I am running the shocks on the outside of the shock tower at the moment or should I change the rear ones to the inside ( would that change the handling )
    Cheers
  2. olds97_lss
    olds97_lss Well-Known Member
    Oct 2, 2015
    1,520
    254
    Dekalb, IL 60115
    What towers do you have? The later model X ones where the body mount goes through the ears on the tower and is retained by big plastic clips or the old ones?
    The later model ones were beefed up to deal with 4 shock setup. I guess over time, they could sag though. Haven't noticed it on my X or flux hp.
  3. xtremsavage
    xtremsavage OG HPISF MEMBER!!!!!
    Apr 15, 2007
    1,809
    8
    Jacksonville, Fl
    I would stick with the stock plastic. Alum towers have no flexibility and also bend easy. You could switch to carbon fiber if you can find some for the savage, but modifications to make them work will be in order.
  4. Savage 6768
    Mar 28, 2018
    51
    9
    New Zealand
    They are off the flux hp so gather the newer ones. When I compress the suspension the shock tower flexs but I gather they all do that being plastic. I have a new one in my spares so I might just swap it out and see how it goes. Will it hurt by putting the shock on the inside as only using 4 of the hpi big bore shocks not the 8 shock set up ?
  5. olds97_lss
    Oct 2, 2015
    1,520
    254
    Dekalb, IL 60115
    I can't imagine there would be issues moving the shocks to the inside, as long as there's clearance for the front tie-rod and rear turnbuckle.
Share This Page
