Venom hump pack
got a pic you can post so I can see the connector ??
I recently won one with the same part #1504 and it plugs right into my stock wiring system
no but it says it has a universal receiver connector
Mine is setup with a flat 3 connector with 2 of the slots filled with black and red wires, it plugs right into my switch harness like a dream. is your switch harness a flat 3 connector also or is it something different..... some are just a small 2 pin red connector on the switch so you may have to make or get an adaptor cable,
this one is a common JST connector used by some switches...
The other one used is like this a flat 3 setup minus the white wire in the pic only using red and black commonly used by Futaba radio switch setups
images
I am thinking you will need this connector adaptor
This would be a jst male to futaba female connector
