Used to be a savage flux
2QIK4U
Theres still a few orig parts left...;)
* hardened F&R diff centres
* hardened axles
* 10mm axle extenders w 17mm wheelnuts
* full set of plaig sealed bearings with ptfd lube (inc gearbox and steering)
* 25T pinion gear....testing 17-21
* 45T hardened main gear
* 36T hardened middle gear
* gpm red alloy lower a-frames F&R
* gpm red alloy adjustable top arms
* gpm silver alloy castor/steering knuckles
* high strength steel ball joint ends/ steering turnbuckles
* 20kg waterproof steering servo
* gpm silver alloy steering assembly with 4xbearings
* titanium servo arm
* 6mm dia drive shafts
* gpm silver alloy F&R diff housings
* big bore alloy shocks and springs (1xF, 2xR)
* custom 30mm hardened plastic "wheelie" with 2 x sealed bearings
* stainless steel F&R skid plates
* custom front bullbar
* 4 x headlights w high output cree directional leds
* 2 x driving lights x directional 4xsme leds per light
* 110mm lightbar with 12x sme leds
* 4 x red led tail lights
* fibreglass wrap on main power leads
* standard side rails painted white
* diffs running 10k wt oil + ptfd additive
* LiPo 3S 11.1 1300mah 35C battery for lights
* running 5000mah 2S and 5000 3S
* JBL bluetooth speaker
* Proline 3.4" black wheels and trencher dirt tyres
* custom roof mounted "roll tyre"
* Spektrum dx5pro and 2100 receiver
Big list with no pictures! You have angered the forum gods! Post up your pictures now, lest you be burned!
Seriously though, post up some pics of your build. ;)
Hahahahaha.......please don't burn me as a sacrifice!!!!! Lol
20190611_172037.jpg20190604_220424.jpg20190520_214707.jpg20190520_214636.jpg20190520_214822.jpgthese are a bit dark20190706_194636.jpg..need to get it outside for some decent pics
The forum gods have been appeased. You may live.
