So what happens if you lean or richen the hsn? I would lean first.
What temps is it getting to as my STS only wakes up after getting to 220F.
Assume the nitro fuel isnt 4 years old.
Hello and thank you for replying,So what happens if you lean or richen the hsn? I would lean first.
How loose/tight are the needles? Perhaps the o-ring in the needles arent sealing so well after all this time?
If adjusting the hsn sees no change in performance then take the carb off, disassemble and soak, give it a good clean.
I cant remember if some STS carbs were problematic, but i know the hpi k4.6/5.9 carb fits and works in the sts 28/30 as used in mine.
Does it restart ok after warming up?
I don't know off top my head but it will vary anyway.
Do you have a fuel filter?
Have you checked fuel tank lid seal is good?
Is the pipe gummed up with old fuel?
is the rear engine exhaust seal good?
Worth checking the engine head bolts are tight, had this the other day where my engine seem to lack power & one of the bolts was loose the exhaust gasket was worn also!??
