Throttle servo
Skateboarder
The servo that runs the throttle and brakes will not move. The batteries are are fully charged but still it doesn't move unless you nudge it along. This happened suddenly yesterday I was driving it and it just stopped responding to the trigger. The steering however works fine, only throttle and brakes servo doesn't move.
sounds as if your servo has failed. there are many out on the market, e bay, amazon, a main, rc planet, your local hobby shop are all good places to look for a replacement.....
find something at least 150 ozin for throttle and brake duties....
Before you replace the servo, though that is the likely issue, remove the linkage and verify that there is no binding first.
Your servo saver could of went bad. I was having bad response on the steering. Took it all a part metal servo was good. Teeth had striped out.
