Zane Lewis
Ok I’ll look into it. ThanksOn that one you have there the spring is actually probably inside that big round looking servo horn. Might be worn out. Your servo may also be worn out. Just turn the truck on and hold the front wheels with one hand and steer with the other, and see what part is slipping, or giving way
Thanks for the diagram that helps a lot@Zane Lewis here is what @upbasher1 is talking about ....
Also make sure your batts are new/charged..
View attachment 7134View attachment 7134
This is what I’m working with. The steering is perfect when off the ground,but on the ground it’s not too good.
If it was to be the servo spring how would I get to it to tighten it? I’ve taken it apart this morning and couldn’t find it. No I’m not using the stock battery. I’m using a 1600 duratrax 6v hump back battery. It steers good driving ,but isn’t greatLooks like a combination of a stock servo and a weak servo saver spring, you can get around that by installing the later steering system and a better servo, for servos I have been using powerhd servos lately and they are great... one final question is are you still using the 4 cell battery holder that came stock, if so consider upgrading to a 5 cell rechargable hump pack they have a bit more voltage and will add some power to your servos
https://www.ebay.com/itm/Power-HD-L...535598&hash=item5460ceafe3:g:t0sAAOSw~AhbXu3z
https://www.ebay.com/itm/HPI85058-H...319028&hash=item1c7b26bbf4:g:JgYAAOSwO7dcAWp-
https://www.ebay.com/itm/Tenergy-5-...dUAAOSwYIxX~S77:sc:USPSFirstClass!95422!US!-1
So would it be this? If so would I have to tighten/ loosen? I’ve never had this truck before I’m new to the savage sorry for all the troubleThat diagram above gives a good view of that servo saver and how to take it apart.... you can tighten up the spring coil by closing down the gap and installing it back into the housing then reinstalling it on the vehicle.....
Ok. Thanksthe spring is located in the round black object attached to the servo output splines, take off the linkage and remove the screw in the middle of the round saver you may have to wiggle it off the splines, (make a note or take a pic of where the linkage is when the wheels are centered so you can reinstall in the same position) and put it on the bench where you can take it apart.....
Yeah I’ve had it to the dual rate, still may just be the spring in the truck. I’m going to just leave it as is because I’m confused on what to do these trucks are a pain!@Zane Lewis If you have the HPI Controller there is an adjustment that slows down/ speeds up the steering responce, you might look for that adjustment before tearing into truck See attached , Its labeled as STEERING DUAL RATE or DUAL RATE on other brands of controllers.... See at top center of page .
Would The spring be in the horn?@Zane Lewis If you have the HPI Controller there is an adjustment that slows down/ speeds up the steering responce, you might look for that adjustment before tearing into truck See attached , Its labeled as STEERING DUAL RATE or DUAL RATE on other brands of controllers.... See at top center of page .
I’ve never had a nitro car before and I just got this used on eBay about a week ago. So I don’t know what I’m dealing with I just don’t wanna take apart anything and won’t know how to put it back on. I need some help! I don’t understand what the items mean on the truck because the seller didn’t have a manual so I have to go online and look at parts. I just hope someone can help me the best they can.NOTHING GOOD IS EASY....
Thank you! I’ll look into itThe spring is under where you have circled here , exploded diagram on pic I provided , page 38 part # 85051
Thank you for all of your help!You can find the manuals online right at this forum, https://www.hpisavageforum.com/forums/hpi-savage/ they are stickied at the top of the forum pages you are looking for
There are SEVERAL Iterations of the savage platform and the one you have looks to be an early 25 model with some owner alterations, Most all the parts interchange between the nitro models so that is a help....
Like I said above the combination of weak servo the sf2 was never a powerhouse, simply adequate for the job and a poor servo saver design are to blame for the steering, but you are in luck because with a bit of wrenching and some parts you can get away from the crappy servo saver and install the steering system off a later model...
Don't be afraid of taking things apart, you will need a few tools to make it easier, a good set of Hex Drivers available online or at any decent hobby store, a good number 2 phillips screwdriver, I have used a 4 way screwdriver with good success and it has all the sizes in 1 handle..
if you get in trouble the guys here are a good bunch and can help you get thru any of the bumpy spots
https://www.hpisavageforum.com/threads/the-complete-beginners-guide-to-rcs.814/
https://www.hpisavageforum.com/threads/hpi-savage-25-manual-and-parts-listing.14274/
https://www.hpisavageforum.com/threads/list-of-useful-nitro-engine-threads.13941/
Lots of reading and rereading , but those things I linked will help you get started.......
So would I have to replace that whole thing?The spring is under where you have circled here , exploded diagram on pic I provided , page 38 part # 85051
Before replacing it you should verify it is indeed the problem. Turn the truck and radio on and flip the truck upside down. Hold the front wheels with one hand and steer the controller with the other. If the servo is moving (You will hear it) but that round servo horn isn't, then you have isolated it as the problem. Now on the other hand, if you do this and the servo itself fails or struggles to move at all when you hold the wheels, then the servo is weak/dying OR you have a bad/low reciever battery not pumping out enough voltage
Yeah turns good , but just thought it would turn as good when it’s off the ground.Also its worth noting that even as it is in your video, the truck will most likely still drive and steer fine. While moving forward its a lot easier for the servo to turn the wheels, and you might find its not an issue at all. I have driven savages many hours just like that with no problems turning.
