Stalling when giving high throttle !
Birdy
Portadown , Northern Ireland
Hi guys , savage stalling on me when I give it high throttle , and wheels engaging when in idle / neutral . I’ve adjusted Rev trim on remote , set all acres back to factory setting and still on who get it started it runs at high revs !!! Any suggestions ??
bad glow plug or tuning related.. wheels turning is normal when truck is off the ground but should not want to drive away on idle, if so you clutch is sticking and needs some attention
Go back to factory settings on carburettor, set throttle trim back to neutral & manually adjust idle opening on carburettor to about 1mm & go from there. The fact your wheels are spinning in idle suggests either your idle opening is open to wide or your clutch shoes are stuck, with engine not started check you can freely spin clutch bell round.
