yea, after all they already been paid, right?
I have 2 nitro savages in my shop that are useless as nipples on a rooster cause there are no oem tanks to replace the broken ones.i refuse to pay the sole seller on ebay $124 dollars for one and i shouldnt have to re-engineer another manufacturers products on my trucks to make them run
I'd say that was your opportunity to customize. Sad you didn't jump at the chance. For me, a mid tank mod would have happened. Seems like the perfect excuse: "Sorry honey, I had to spend all this money because replacement parts were unavailable."
8t tank i mounted to my xl so i could scavenge the tank for my X. Still missing one for orange crush!
I actually tried to minimized the amount it stuck out past TVP's I wanted the mounts to be inside the plate and the tank to be as far in as possible. but it just wasnt meant to be as i was too lazy to get out the torch, heat the mounts up and tighten those bends(pretty wide bends). those 2 mounts amount to a full afternoon of work now that my welder is back from shop, i may hook up spoolgun and weld some braces on those mounts. I made another set of mounts from aluminum angle, but they failed before i even got the tank fully mounted.
Next winter i will attempt a better set. aluminum rod stock is easy to come by
The tank just wouldnt fit on the X in the stock location. its just too long. maybe i will start looking for a new reciever box to mount outside the chassis plates and attempt to mid-tank mount the other 8T tank i bought, but thats a "next winter" project. Construction season soon calls
