AllanQ
- St. Marys, Ga
My son's front bearing is leaking fuel. My lhs told me this is the beginning of the end for the motor. Although he told me I could change the front bearing if I did not align the front bearing with the rear bearing the motor would be trashed. However, when I asked his opinion on a replacement motor, they recommended a TRX motor and should upgrade to the 3.3. I am not very happy with the TRX engine and I know there has to be a better motor out there. Could anyone recommend a better motor to replace the 2.5 that is in there now?
Also, my lhs told me that if I got 3 gallons of fuel through the engine that I am lucky and have a good motor. This did not make sense to me at all because that means I would be buying a new engine every 3 gallons, sounds like it can get expensive replacing that many engines. I am very particular about maintaining these things so how long should an engine last?
One last thing which did not make much sense is when I asked them if I were to upgrade to the 3.3, would I have to upgrade the transmission or cvd's. They told me I would not have to upgrade anything but I have been advised if I get the bigger motor I need to upgrade the tranny and cvd's so I am kind of confused. Thanks and appreciate any feedback you can give.
