shimmy shimmy
kev544511
danvers.mass
ran my truck quite a few times this past weekend and noiticed besisides what i broke, that the truck seemed not to be real "tight". almost likethe tires were lose but they werent. ugh could those bearings in the hub be bogus in a fairly short time? the thing really shimmyied in the straight away!
water could have gotten in them, the foam can move around a little.
I was running my truck this weekend and the rear tires was shaking, it was like the truck had wheel hop. Did some work to it and the tires got on different corners and the front tires were shaking badly now. I would check the tires first.
check your tie rods make sure there not worn .. heck your drive train and replace worn parts ..
Formiko is right probably your tires and or foams
I drill tiny holes right in the middle of the tire. When they ballon up the water will exit the holes. Should only need a couple.
on inspection of my tires the they do have some 1/4 in cuts in them
water may of gotton in thx boys for the help.
