Settings for this pipe
DocHal 69
I have attached some pictures of the tuned pipe I have on my Savage X 4.6 . Is any one familiar with this pipe? I have lost the instructions .
There is piston that moves in and out in the sleeve. There are 8 different settings for the pin. The closer the pin is set to the inlet side the more pressure on the spring making it harder for the piston to move back in the sleeve. I am not sure where the pin should be located and why.
Appreciate any help.
Thanks Doug
Thankyou very much. That helps a lot. I am going to set the spring in the middle setting for starters.
I may set it out if I want more speed.
