2007st1300abs
Hon, I am looking to put a lrp .32 engine in my savage x . What should I do to upgrade the clutch and any other comments to handle the extra power ?
Make sure you have hardened steel spur gear and clutchbell, and the newest bulletproof diffs. Other than that you MAY have a issue with the smaller 2nd gear plastic gear in the transmission. If it strips, I believe they make a steel version for that as well. I personally have never stripped the larger one
Ok , what does it come standard with for gears and diffs ?Make sure you have hardened steel spur gear and clutchbell, and the newest bulletproof diffs. Other than that you MAY have a issue with the smaller 2nd gear plastic gear in the transmission. If it strips, I believe they make a steel version for that as well. I personally have never stripped the larger one
Ok , I’m not sure what it has . Can both of the gears in the transmission be upgraded ??What differentials it has will depend on what model of savage you have. However the transmissions all have the plastic gears on the middle rack
, is the stock gears pretty good ? Or is there room for improvement?I'm honestly not sure. I believe they sell a delrin set but I have never upgraded them my self so it is a little beyond my knowledge
