Savage X 4.6 Throttle/ Brake Servo Horn Replacement
gutshot
Atlanta
Ok... so diving deeper on my lightly used X I took apart the T/B horn and I'm not sure of the reassembly sequence. That's the first problem. My second problem is the existing T/B horn is marked 23 (AirTronic) and I want to move to a Hitec (24) or perhaps Savox (25) servo and I cannot seem to find replacement horns anywhere on the net. Appreciate the assist in advance
Thanks again sir... What is the best /easiest upgrade? The OFNA mod?
Yep. The ofna sliders are hard to come by these days but there are alternatives. Go on ebay and just search for throttle linkage lol. Theres a ton of options and you can just get creative
Yeah, something like this has the sliders/collars you need:
https://www.ebay.com/itm/RC-NITRO-LINKAGE-OFNA-BRAKE-THROTTLE-98-30800-NEW/323781501209
But you will still need the longer wires that come with yours.
This was on an old savage I had:
On my current X, I didn't have plastic sliders and used the traxxas metal ones, which I don't particularly care for:
Why did you have that exhaust spring fitted on your b/t linkage olds97_Iss May I ask?
I didn't have a good one that would wrap around the carb neck and connect to the HSN, so I put one on the arm at least to put positive pressure on it when it was at idle vs setting the spring on the servo end so tight that it made the servo hum all the time. The servo was plenty strong to overcome it, but if I lost power, this would at least be better than nothing. It just wouldn't help if the ball end popped off the carb.
