Savage Wish bones
guinnessdublin
England
The Wishbones & steering knuckles for a savage x are they the same fitment size/dimensions as my savage 21 does anyone know please?
They do differ, but I can't recall all of what differs about them. Other than they aren't interchangeable from side to side/front to back like the old ones were. The old ones had ears for the shocks that stuck up on both sides of the arms, so you could literally use any arm on any corner by flipping it. Was very nice and universal. All you had to have on hand was 1 arm as it could replace any arm. But now they only work on opposing corners. Like the front left will work on the rear right only.
Other than that, I don't know if there are other geometry changes as I know the X has a lower CG, but I can't recall if that's at the wheel hub as well as the transmission or just the transmission was dropped down in the center some.
I found this:
https://www.rctalk.com/forum/threads/savage-x-parts-compatibility-list.42083/
Looks like the arms are listed as compatible. You just lose the ability to use any arm on any corner of the truck.
Copied from HPI's site...
Savage X parts that WILL fit on past Savage trucks:
Nylon Roll Hoop (more durable)
Nylon Rollcage (engine protection)
Warlock Wheels* (stronger 17mm hex hub)
17mm Hex Hubs (stronger)
GT-2 Tires (lighter)
Turnbuckles (easier to adjust) Transmission Case (easier to remove)
Differential Housings* (front and rear)(easier to remove)
Shock Towers (additional shock locations)
Suspension Arms (lighter)
Radio Box (easier access)
Slipper Clutch (dual pads plus rubber dampening)
Savage X Chassis Plates* (lowered CG)
F4.1 Engine
* May require a few extra parts for conversion
Parts carried over from past Savage trucks:
Internal Differentials
Internal Transmission
Dogbones
Driveshafts
Brake
Axles
Exhaust
Uprights
C Hubs
Body Posts
Body Position
Engine Mount & Plate
Servo Saver
Shocks and Springs
Past Savage parts that WILL NOT fit on the Savage X:
Alloy Roll Hoop
Spur Gears (hardened steel gears will fit with new inner hub)
Polycarbonate Receiver Cover
