Savagex2315
Ok so I replaced my clutch shoes for my Savagex and I went plastic worked good first couple passes then went to poop. As I was starting it up it would grab but then you can hold it on the ground and full throttle it and the bell gear just spins and when I run it with out holding onto it all it does is stay in first gear. Was shifting fine when I first started it went through all 3 gears. I have a axial 32 motor in it.. is the problem the clutch shoes??
