Savage clutch bell
guinnessdublin
England
Yes that’s agood shout using an old bearing, have been using shims & brass washer which are used on centre of spur gear I think, but noticed centre hole had worn oval shaped which never had that happen before! 👍🏻
olds97_lss
Dekalb, IL 60115
I use the inner race for spacers a lot. Kind of why I tend to keep all my old worn out bearings. I just cut the outside race with a dremel and it usually will pop right off. Then I have a good 1mm thin shim/spacer that is 4-5mm wide depending on the bearing.
