Savage 21 and 25
Thread starter #1
Zep71
Likes
16
Ray City GA
I have 2 of my Savages running going to get ready for #3
thesmilingpirate
Likes
25
Long Island, New York
What seems to be the problem with it ?
Truck doesn’t move on the ground but wheels move when off the ground. Have ripped this truck apart 6 times already. Changed spur gear, clutch bell, checked all upper and lower transmission parts, checked front and rear diffs, checked OWB, checker clutch holder (86087) which I read could’ve been a bad factory part from ‘09. Even ordered a new one in case I need it.
Have to make some adjustments today and then will be trying again. Not optimistic though. Only thing I haven’t changed is the clutch but it still looks good. Can still see the numbers on the outside of the clutches.
Thread starter #10
Zep71
Likes
16
Ray City GA
and your slipper clutch is good?
X
Conspiracy of One
HPISF Staff
Likes
446
Minnesota
Have you checked to make sure all of the drive cups have their grub screws installed? What I'm talking about are part number 86094 in the first image. 86095 in the second.
Not uncommon for those to fall out and cause an issue like what you are seeing. Check both outdrives from the transmission as well as the drive cups on the pinion for the diffs. If some are missing, make sure to add some loctite when you reinstall.
thesmilingpirate
Likes
25
Yes. I checked and both were there and tight.
Thread starter #18
Zep71
Likes
16
Ray City GA
Likes
9
I know this sounds kinda basic but is there a chance the brake setup is partially froze up such that with no load on the wheels they will turn but when on the ground froze up.
Jam Racing 1
NPTB Monitor, Master of the known universe....
HPISF Staff
Likes
640
I agree clutch shoes do not look all that bad, possibly oil in the bell?? that will make those funky phenolic/plastic shoes slip like mad and not transmit the power....
Alloy shoes are the only way to fly if ya ask this old man :)
thesmilingpirate
Likes
25
ok good luck hope you get it sorted out but to me your clutch shoes look fine.Do they move out ok by using your fingers?
Thanks @js1badsti Me too! Yes, I can move them out with my fingers and no broken springs.
Bell is brand new and hasn't had a run through since it was installed. Since the new clutch shoes and springs will be here Friday, I'll find out soon enough if the clutch is the issue.
X
Conspiracy of One
HPISF Staff
Likes
446
Minnesota
I would follow driveline movement as it sits on the ground. When you hit the throttle, does the clutch bell turn? If so, watch the back of the slipper clutch assembly, does that turn? Then look at the outdrives on the transmission, do they turn? Somewhere along the line stuff won't be moving, that's where you should be looking.
thesmilingpirate
Likes
25
Thanks @X Clutch shoes and springs should be arriving this week. Once I get them in I will check all of the above. Appreciate the good info.
thesmilingpirate
Likes
25
Parts arrived Friday and finally got around to getting them installed this morning. Happy to say that the issue has been resolved. It was the clutch shoes and springs. Took it out for a quick test and I'm already loving the way the Mugen 1.0 springs are responding. Hoping to get longer life out of the Dynamite Aluminum clutch shoes.
Only ran it for 5 minutes even though I wanted to run it for a few hours but with the holiday's approaching, and the wife having some things on the "Honey Do" list, I cut it short.
Thank you to all in this thread who helped with their suggestions.
